DJI Mavic 3 Pro Fly More Combo (RC)
Quicklinx: HNZWWS00 Mfr#: CP.MA.00000660.01
Type: [N/A]
£2,124.17 ex VAT
£2,549.00 inc VAT
The DJI Mavic 3 series features next-level imaging performance. Mavic 3 Pro's triple-camera system ushers in a new era of camera drones by housing three sensors and lenses with different focal lengths. Equipped with a Hasselblad camera and dual tele cameras, Mavic 3 Pro is a triple-camera drone that unlocks new shooting perspectives, allowing you to embrace creative freedom further, capture fascinating scenery, explore photographic storytelling, and make cinematic masterpieces.
  • Flagship tri-camera system
    With a 4/3 CMOS Hasselblad camera, a 70mm tele camera, and a 166mm tele camera, Mavic 3 Pro helps you create stunning works in various scenarios.
  • 4/3 CMOS Hasselblad camera
    The Hasselblad camera shoots 5.1K/50fps and 4K/120fps with a f/2.8 - f/11 range. The 10-bit D-Log M mode records up to one billion colors.
  • Apple ProRes for pro creation
    Mavic 3 Pro Cine has triple camera Apple ProRes codec support. It also has a built-in high-capacity SSD and a 10Gbps lightspeed data cable.
  • 43-min max flight time
    Mavic 3 Pro gives you more confidence to fly further while enjoying aerial photography creation. Execute every step during a single flight.
  • Omnidirectional obstacle sensing
    Mavic 3 Pro allows you to fly even in complex environments. Eight sensors and powerful computing engine sense obstacles and plan a safe route.
  • 15km HD video transmission
    DJI O3+ supports a transmission distance of up to 15 km and 1080p/60fps live feed, for smoother control.
  • Thrilling immersive flight
    Experience immersive FPV when you use DJI goggles along with the DJI RC Motion 2. Enjoy true-to-life colors, accurate details, and motion controls that make flying captivating.
DJI Mavic 3 Pro Fly More Combo (DJI RC) - drone
Drone
Included Items
Power adapter, power cable, remote controller, USB-C cable, shoulder bag, pair of spare control sticks, 3 intelligent flight batteries, 6 pairs of low-noise propellers, storage cover, 100W battery charging hub, ND filter set (ND8/16/32/64)
Category
Vehicles - drones
Camera
Included - 20 Megapixel
Max Speed
21 metres per second
Navigation
GPS/Galileo/BeiDou
Wi-Fi
9.8 cm
23.11 cm
9.54 cm
958 g
1 year
Drone
Included Items
Category
Vehicles - drones
Remote Control
Yes - 5.8 GHz - max operating distance: 15000 m
Power Source
Max Speed
Supported Flash Memory Cards
microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card up to 512 GB
Obstacle avoidance system
RC Vehicle
Flash Memory
8 GB
Vertical Hovering Accuracy
+/- 0.1 metres
Horizontal Hovering Accuracy
+/- 0.3 metres
Max Tilt Angle
35°
Max Ascent Speed
8 metres per second
Max Descent Speed
6 metres per second
Max Wind Speed Resistance
12 metres per second
Navigation
GPS/Galileo/BeiDou
Wi-Fi
Wi-Fi Bands
2.4 GHz, 5.8 GHz
Gimbal
Control Angle Range
-140 to 50° (tilt), +/- 50° (roll), -23 to 23° (pan)
Max Speed
100° per second (tilt)
Digital Camera
Sensor Resolution
20 Megapixel
Image Sensor Type
CMOS
Focus Adjustment
Automatic
Capture Formats
MP4/MOV (MPEG-4 AVC/H.264, HEVC/H.265), MOV (Apple ProRes 422 HQ/422/422 LT)
Video Recorder Resolutions
1920 x 1080 (1080p), 3840 x 2160, 4096 x 2160, 5120 x 2700
Still Image Formats
JPEG, RAW, DNG
Still Image Resolutions
5280 x 3956
Max View Angle
84 degree(s)
Rechargeable Battery
Rechargeable
Supported Battery Configurations
4S
Lithium Ion
Voltage
15.4 V
5000 mAh
Run Time
Up to 43 min
Warranty
1 year
Dimensions
23.11 cm x 9.8 cm x 9.54 cm
958 g
Choking Hazard Warnings
Dimensions & Weight Details
Battery - 335.5 g
-10 °C
Type: [N/A]
Brand: DJI
Price Range Ex VAT: £1500+
