The DJI Mavic 3 series features next-level imaging performance. Mavic 3 Pro's triple-camera system ushers in a new era of camera drones by housing three sensors and lenses with different focal lengths. Equipped with a Hasselblad camera and dual tele cameras, Mavic 3 Pro is a triple-camera drone that unlocks new shooting perspectives, allowing you to embrace creative freedom further, capture fascinating scenery, explore photographic storytelling, and make cinematic masterpieces.
                Flagship tri-camera systemWith a 4/3 CMOS Hasselblad camera, a 70mm tele camera, and a 166mm tele camera, Mavic 3 Pro helps you create stunning works in various scenarios.
                4/3 CMOS Hasselblad cameraThe Hasselblad camera shoots 5.1K/50fps and 4K/120fps with a f/2.8 - f/11 range. The 10-bit D-Log M mode records up to one billion colors.
                Apple ProRes for pro creationMavic 3 Pro Cine has triple camera Apple ProRes codec support. It also has a built-in high-capacity SSD and a 10Gbps lightspeed data cable.
                43-min max flight timeMavic 3 Pro gives you more confidence to fly further while enjoying aerial photography creation. Execute every step during a single flight.
                Omnidirectional obstacle sensingMavic 3 Pro allows you to fly even in complex environments. Eight sensors and powerful computing engine sense obstacles and plan a safe route.
                15km HD video transmissionDJI O3+ supports a transmission distance of up to 15 km and 1080p/60fps live feed, for smoother control.
                Thrilling immersive flightExperience immersive FPV when you use DJI goggles along with the DJI RC Motion 2. Enjoy true-to-life colors, accurate details, and motion controls that make flying captivating.
- DJI Mavic 3 Pro Fly More Combo (DJI RC) - drone
- Product Type
- Drone
- Included Items
- Power adapter, power cable, remote controller, USB-C cable, shoulder bag, pair of spare control sticks, 3 intelligent flight batteries, 6 pairs of low-noise propellers, storage cover, 100W battery charging hub, ND filter set (ND8/16/32/64)
- Category
- Vehicles - drones
- Camera
- Included - 20 Megapixel
- Max Speed
- 21 metres per second
- Navigation
- GPS/Galileo/BeiDou
- Interface
- Wi-Fi
- 9.8 cm
- 23.11 cm
- 9.54 cm
- 958 g
- 1 year
- Product Type
- Drone
- Included Items
- Category
- Vehicles - drones
- Remote Control
- Yes - 5.8 GHz - max operating distance: 15000 m
- Power Source
- Battery
- Max Speed
- Supported Flash Memory Cards
- microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card up to 512 GB
- Obstacle avoidance system
RC Vehicle
- Flash Memory
- 8 GB
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Tilt Angle
- 35°
- Max Ascent Speed
- 8 metres per second
- Max Descent Speed
- 6 metres per second
- Max Wind Speed Resistance
- 12 metres per second
- Navigation
- Interface
- Wi-Fi
- Wi-Fi Bands
- 2.4 GHz, 5.8 GHz
Gimbal
- Control Angle Range
- -140 to 50° (tilt), +/- 50° (roll), -23 to 23° (pan)
- Max Speed
- 100° per second (tilt)
Digital Camera
- Sensor Resolution
- 20 Megapixel
- Image Sensor Type
- CMOS
- Focus Adjustment
- Automatic
- Capture Formats
- MP4/MOV (MPEG-4 AVC/H.264, HEVC/H.265), MOV (Apple ProRes 422 HQ/422/422 LT)
- Video Recorder Resolutions
- 1920 x 1080 (1080p), 3840 x 2160, 4096 x 2160, 5120 x 2700
- Still Image Formats
- JPEG, RAW, DNG
- Still Image Resolutions
- 5280 x 3956
- Max View Angle
- 84 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 4S
- Technology
- Lithium Ion
- Voltage
- 15.4 V
- Capacity
- 5000 mAh
- Run Time
- Up to 43 min
- Warranty
- 1 year
- Dimensions
- 23.11 cm x 9.8 cm x 9.54 cm
- 958 g
Choking Hazard Warnings
- Dimensions & Weight Details
- Battery - 335.5 g
- -10 °C
- 40 °C
