Imaging capabilities
The 20 megapixel CMOS sensor allows for image quality, including still images and 4K video recording. Capture details and colors accurately, making it suitable for a variety of professional applications. -
Battery performance
The lithium cobalt oxide battery with a capacity of 5000 mAh provides reliable power, ensuring that the drone can remain airborne for extended periods. Its rechargeable design also supports multiple uses. -
Navigation and control
Equipped with GPS/GLONASS/BeiDou/GALILEO navigation systems, this drone offers precise positioning along with an accomplished RC Pro remote control that extends the operating range up to 15 km. -
Design for outdoor use
Designed to operate efficiently in various weather conditions, the DJI Mavic 3 Multispectral can withstand temperatures ranging from -10°C to 40°C, making it a suitable choice for outdoor applications.
- DJI Mavic 3 Multispectral - drone
- Product Type
- Drone
- Included Items
- Carrying case, charger, intelligent flight battery, pair of propellers, DJI RC remote controller, power cable, USB-C cable, manual
- Category
- Vehicles - drones
- Camera
- Included - 20 Megapixel
- Max Speed
- 15 metres per second
- Navigation
- GPS/GLONASS/BeiDou/GALILEO receiver
- Interface
- Wi-Fi, Bluetooth
- Outdoor
- 28.3 cm
- 34.75 cm
- 13.96 cm
- 951 g
- Product Type
- Drone
- Included Items
- Category
- Vehicles - drones
- Size
- 380.1 mm
- Remote Control
- Yes - 5.8 GHz - max operating distance: 15 km
- Power Source
- Battery
- Outdoor
- Max Speed
- Supported Flash Memory Cards
- microSDHC, microSDXC up to 512 GB
- Obstacle avoidance system
RC Vehicle
- Take-Off Weight
- 1050 g
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Angular Velocity
- 200° per second
- Max Tilt Angle
- 35°
- Max Ascent Speed
- 8 metres per second
- Max Descent Speed
- 6 metres per second
- Max Wind Speed Resistance
- 12 metres per second
- Navigation
- Interface
- Wi-Fi, Bluetooth
- Wi-Fi Bands
- 2.4 GHz, 5.8 GHz
Gimbal
- Control Angle Range
- -90 to 35° (pitch)
- Max Speed
- 100° per second (tilt)
Digital Camera
- Sensor Resolution
- 20 Megapixel
- Image Sensor Type
- CMOS
- Focus Adjustment
- Manual
- Capture Formats
- MP4 (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 3840 x 2160 (4K) at 30 fps, 1920 x 1080 (1080p) 30fps
- Still Image Formats
- DNG, JPEG, RAW
- Still Image Resolutions
- 5280 x 3956
- Max View Angle
- 84 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 4S
- Technology
- Lithium cobalt oxide
- Voltage
- 15.4 V
- Capacity
- 5000 mAh
- Run Time
- Up to 43 min
- IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.1, IEEE 802.11ax (Wi-Fi 6)
- Dimensions
- 34.75 cm x 28.3 cm x 13.96 cm
- 951 g
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded without propellers - 9.63 cm x 22.3 cm x 12.22 cm , Unfolded - 28.3 cm x 34.75 cm x 13.96 cm , Battery - 335.5 g
- -10 °C
- 40 °C
