DJI Mavic 3 Multispectral (ENT)
Quicklinx: HW8YWS00 Mfr#: CP.EN.00000445.01#EDU
Effective aerial surveying needs to see the invisible. That's why Mavic 3 Multispectral has two forms of sight. It combines an RGB camera with a multispectral camera to scan and analyze crop growth with total clarity. Agricultural production management requires precision and data, and Mavic 3M delivers both.
  • Highly integrated imaging system
    Newly upgraded imaging system with one 20MP RGB camera and four 5MP multispectral cameras (green, red, red edge, and near infrared). Enables applications such as high precision aerial surveying, crop growth monitoring, and natural resource surveys.
  • Sunlight sensor
    The built-in sunlight sensor captures solar irradiance and records it in an image file, allowing for light compensation of image data during 2D reconstruction. This results in more accurate NDVI results, as well as improved accuracy and consistency of data acquired over time.
  • Accurate images that capture every pixel
    Mavic 3M with RTK module for centimeter-level positioning. Flight control, the camera, and the RTK module sync in microseconds to accurately capture the location of each camera's imaging center. This enables Mavic 3M to do high-precision aerial surveying without using ground control points.
  • Orchard mapping
    Mavic 3M allows terrain-follow aerial surveying of orchards, even on sloped landscapes. Together with DJI Terra or DJI SmartFarm Platform to reconstruct high-resolution orchard maps, automatically identify the number of trees, distinguish trees from other obstacles or objects, and generate three-dimensional operation routes for agricultural drones, making operations safer and more efficient.
  • Intelligent field scouting
    The Mavic 3M can carry out automatic field scouting. The field scout images can be uploaded to the DJI SmartFarm Platform in real time through a 4G network. It can find abnormalities, such as emergence deficiencies, weed pressure, and crop lodging in a timely manner. It can also conduct intelligent analyzes, such as cotton seedling identification and rice production testing, using AI identification for real-time sharing of crop growth information, guidance of agronomic activities, and easy management of 70 hectares of farmland by one person.
  • Environmental monitoring and natural resources survey
    The Mavic 3M can also be used in environment and natural resource surveys, such as water enrichment monitoring, forest distribution surveys, urban green area surveys, and more.
DJI Mavic 3 Multispectral - Aircraft
Aircraft
Included Items
Carrying case, charger, screwdriver, 3-Axis gimbal, intelligent flight battery, USB-C cable, 3 pairs of propellers, DJI RC remote controller, USB-C to USB-C cable
Category
Vehicles - drones
Camera
Included - 20 Megapixel
Max Speed
15 metres per second
Navigation
GPS/GLONASS/BeiDou/GALILEO receiver
Bluetooth, Wi-Fi
Outdoor
28.3 cm
34.75 cm
13.96 cm
951 g
Aircraft
Included Items
Category
Vehicles - drones
Size
380.1 mm
Remote Control
Yes - 5.8 GHz - max operating distance: 15 km
Power Source
Outdoor
Max Speed
Supported Flash Memory Cards
microSDHC, microSDXC up to 512 GB
Obstacle avoidance system
RC Vehicle
Take-Off Weight
1050 g
Vertical Hovering Accuracy
+/- 0.1 metres
Horizontal Hovering Accuracy
+/- 0.3 metres
Max Angular Velocity
200° per second
Max Tilt Angle
35°
Max Ascent Speed
8 metres per second
Max Descent Speed
6 metres per second
Max Wind Speed Resistance
12 metres per second
Navigation
Bluetooth, Wi-Fi
Wi-Fi Bands
2.4 GHz, 5.8 GHz
Gimbal
Control Angle Range
-90 to 35° (pitch)
Max Speed
100° per second (tilt)
Digital Camera
Sensor Resolution
20 Megapixel
Image Sensor Type
CMOS
Focus Adjustment
Manual
Capture Formats
MP4 (MPEG-4 AVC/H.264)
Video Recorder Resolutions
1920 x 1080 (1080p) 30fps, 3840 x 2160 (4K) at 30 fps
Still Image Formats
JPEG, RAW, DNG
Still Image Resolutions
5280 x 3956
Max View Angle
84 degree(s)
Rechargeable Battery
Rechargeable
Supported Battery Configurations
4S
Lithium cobalt oxide
Voltage
15.4 V
5000 mAh
Run Time
Up to 43 min
802.11ax, Bluetooth 5.1
Dimensions
34.75 cm x 28.3 cm x 13.96 cm
951 g
Choking Hazard Warnings
Dimensions & Weight Details
Folded without propellers - 9.63 cm x 22.3 cm x 12.22 cm , Unfolded - 28.3 cm x 34.75 cm x 13.96 cm , Battery - 335.5 g
-10 °C
