- DJI battery charger - with battery - 3 - Li-pol - Mavic Intelligent Flight Battery connector - 100 watt
- Product Type
- Battery charger + battery
- Designed For
- Drone battery
- 5.5 cm x 15 cm x 2.8 cm
- 116 g
- Output Connector Type
- Total 3: Mavic Intelligent Flight Battery connector
- Voltage Required
- 5 - 20 V
- Max Electric Current
- 5 A
- Battery
- Lithium polymer - 5000 mAh 4S
- Power Provided
- 100 watt
- Supported Battery
- 3 lithium polymer
- Batteries Included
- 3 pcs.
- 1-year warranty
- Product Type
- Battery charger battery
- Designed For
- Drone battery
- 5.5 cm
- 15 cm
- 2.8 cm
- 116 g
- Voltage Required
- 5 - 20 V
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Output connectors
- Power Provided
- 100 watt
- 5 A
- AC Power Adaptor Required
- LED indicator
- Technology
- Lithium polymer
- Cell Arrangement
- 4S
- Included Qty
- 3
- Capacity
- 5000 mAh
- Battery level indicator
Supported Battery
- Max Supported Qty
- 3
- Technology
- Lithium polymer
- Limited warranty - 1 year
