The Mavic 2 Pro commands a powerful 1-inch CMOS sensor, offering stunning 20-megapixel aerial photos with extreme detail. Designed by Hasselblad in collaboration with DJI, the L1D-20c camera houses an adjustable-aperture lens, providing more control over your lighting environment.
1-inch CMOS sensor
The brand new 1-inch CMOS sensor has an active sensing area four times more effective than the original Mavic Pro. The large sensor also means better performance in low-light environments with a more extensive ISO range, max ISO lifted from 3200 to 12800. -
10-bit Dlog-M color profile
The Mavic 2 Pro supports a 10-bit Dlog-M color profile that yields higher dynamic range for more flexibility in the grading room. The system records over 1 billion colors (compared to the 16 million colors from traditional 8-bit color coding technologies) and retains more in-depth details in both highlights and shadows. Now you can capture the subtlest gradations at sunset or sunrise, leaving greater space for post-production. -
HDR video
With 4K 10-bit HDR support, the Mavic 2 Pro can be plugged into a 4K TV with HLG and will immediately play back footage with the right color tones. The brighter highlights and increased contrast are what make HDR video so appealing. -
Adjustable aperture
The f/2.8-f/11 adjustable aperture delivers outstanding image quality both in high and low-light environments. When shooting in low light, set the aperture to f/2.8 to allow more light in and to capture bright and clear photos. When shooting in well-lit environments, set the aperture to f/11 to lower the shutter speed and make your videos smoother.
- DJI Mavic 2 Pro - quadcopter
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- iPhone, iPad, Android phone
- Camera
- Included - 20 Megapixel
- Max Speed
- 72 kilometers per hour
- Navigation
- GPS/GLONASS receiver
- Interface
- Wi-Fi
- 24.2 cm
- 32.2 cm
- 8.4 cm
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- Size
- 354 mm
- Remote Control
- Yes - 2.4 GHz - max operating distance: 8 km
- Power Source
- Battery
- Max Speed
- Card Reader
- microSDXC UHS-I Memory Card up to 128 GB
- Battery charger, remote controller, camera with gimbal, intelligent flight battery, obstacle avoidance system
RC Vehicle
- Take-Off Weight
- 907 g
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Angular Velocity
- 200° per second
- Max Tilt Angle
- 35°
- Max Vertical Velocity
- 5 metres per second
- Max Horizontal Velocity
- 20 metres per second
- Navigation
- Interface
- Wi-Fi
Gimbal
- Control Angle Range
- -90 to 30° (tilt), -75 to 75° (pan)
- Max Speed
- 120° per second (tilt)
Digital Camera
- Sensor Resolution
- 20 Megapixel
- Image Sensor Type
- CMOS
- Capture Formats
- MOV (MPEG-4 AVC/H.264), MP4 (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 1920 x 1080 (1080p), 3840 x 2160 (2160p), 2688 x 1512
- Frame Rate
- 30 frames per second
- Still Image Formats
- JPEG, DNG
- Still Image Resolutions
- 5472 x 3648
- Max View Angle
- 77 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 4S
- Technology
- Lithium polymer
- Voltage
- 15.4 V
- Capacity
- 3850 mAh
- Run Time
- Up to 31 min
- Dimensions
- 32.2 cm x 24.2 cm x 8.4 cm
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded - 9.1 cm x 21.4 cm x 8.4 cm , Battery - 297 g
- -10 °C
- 40 °C
