The Cellular Dongle 2 enables your DJI equipment to access 4G network connectivity with stable connectivity through Antenna Switch Diversity (ASDIV) and Enhanced Transmission when used in conjunction with a remote controller connected to the internet, so if the Original Video transmission signal is compromised you continue to control your drone with 4G connectivity.
For DJI Mini 4 Pro users, the mounting kit (which includes 4G antennas) is also required.
For DJI Air 3 users, directly insert the Cellular Dongle 2 into the aircraft body, no installation kit required.
The Cellular Dongle 2 integrates with DJI Air 3 and directly inserted into the aircraft body, a separate installation kit is not required. If the OV transmission signal is compromised, continue to control your aircraft via the 4G network.
Tips:
- Drone SIM must be purchased separately
- Purchase Private 4G Server from BT to keep data in the UK
- Check latest CAA guidance ahead of flying
- Ofcom UAS licence required ahead of flying
Drone SIM sold separately, find out more here.
Private 4G Server access sold separately - The private 4G Server architecture built by BT ensures your data such as Media, Control and RTK is protected and remains within the UK when operating over 4G. Find out more by contacting droneconnect@bt.com
In the box:
- Cellular Dongle 2 x1
- Screwdriver x1
- Cable clip x1
Compatibility:
- DJI Air 3
- DJI Mini 4 Pro
