This slim, elegant mouse is an excellent and high-quality input and pointing device for the office or on the road. It has a rubberised scroll wheel that allows noiseless scrolling and clicking.
Precise navigation thanks to three-level mouse sensitivity of 800/1200/1600 dpi. By changing the dpi, you can instantly adjust the pointer speed to suit the type of work you are engaged in. There is no need to install any additional software as the mouse works with Plug & Play. The integrated Nano Receiver simply has to be plugged into the notebook or computer and the mouse is ready to start within a few seconds. The battery runs on one AA battery (not included).
- Quiet clicking and scrolling
- 800/1200/1600 dpi
- User-friendly and quick installation thanks to Nano Receiver
- Plug & Play - no additional software required
- Slim design
- For use in the office or on the road
- DICOTA Silent - mouse - black
- Mouse
- Connectivity Technology
- Wireless
- Black
- 6 cm x 11.8 cm x 3.2 cm
- 50 g
- Wireless Receiver
- USB wireless receiver
- Movement Resolution
- 1600 dpi
- Performance
- Realtime sensitivity switching 800/1200/1600 cpi
- Nano wireless receiver, scrolling wheel, Noiseless wheel technology
- Battery
- AA type
- 2-year warranty
- Mouse
- Wireless Receiver
- 6 cm
- 11.8 cm
- 3.2 cm
- 50 g
- Product Material
- Plastic
- Black
Input Device
- Wireless
- 1600 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AA type
- Limited warranty - 2 years
