Dicota Wireless Mouse Silent
Quicklinx: G346WS00 Mfr#: D31829
This slim, elegant mouse is an excellent and high-quality input and pointing device for the office or on the road. It has a rubberised scroll wheel that allows noiseless scrolling and clicking.
Precise navigation thanks to three-level mouse sensitivity of 800/1200/1600 dpi. By changing the dpi, you can instantly adjust the pointer speed to suit the type of work you are engaged in. There is no need to install any additional software as the mouse works with Plug & Play. The integrated Nano Receiver simply has to be plugged into the notebook or computer and the mouse is ready to start within a few seconds. The battery runs on one AA battery (not included).
  • Quiet clicking and scrolling
  • 800/1200/1600 dpi
  • User-friendly and quick installation thanks to Nano Receiver
  • Plug & Play - no additional software required
  • Slim design
  • For use in the office or on the road
DICOTA Silent - mouse - black
Mouse
Wireless
6 cm x 11.8 cm x 3.2 cm
50 g
Wireless Receiver
USB wireless receiver
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 cpi
Nano wireless receiver, scrolling wheel, Noiseless wheel technology
AA type
Mouse
Wireless Receiver
6 cm
11.8 cm
3.2 cm
50 g
Product Material
Plastic
Input Device
Wireless
Movement Resolution
1600 dpi
Performance
1 x USB - 4 pin USB Type A
Plug and Play
AA type
