The COMFORT Wireless Mouse is the mouse for everyone who needs to be able to work anywhere.
With the precise 1,000 dpi laser, you can complete even the most demanding tasks in no time at all. There is no need to install any additional software, as the mouse works with Plug & Play. The integrated Nano receiver simply has to be plugged into the notebook or computer and the mouse is ready to start within a few seconds. The mouse battery runs on two AAA batteries (not included).
- 1000 dpi
- User-friendly and quick installation thanks to Nano receiver
- Plug & Play - no additional software required
- For use in the office, at home or on business travel
- DICOTA Comfort - mouse - black
- Mouse
- Connectivity Technology
- Wireless
- Black
- 6.6 cm x 10.4 cm x 3.9 cm
- 100 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Nano wireless receiver, scrolling wheel
- Battery
- AAA type
- 2-year warranty
- Mouse
- Wireless Receiver
- 6.6 cm
- 10.4 cm
- 3.9 cm
- 100 g
- Product Material
- Plastic
- Black
Input Device
- Wireless
- Optical
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AAA type
- Limited warranty - 2 years
Dicota Wireless Mouse Comfort
