Dicota Wireless Laser Presenter
Quicklinx: HQFJWS00 Mfr#: D32075
28 In Stock
£22.58 ex VAT
£27.09 inc VAT
Discover the DICOTA presentation remote control, a device designed to elevate your presentation game. With its rechargeable battery, you can rely on it for extended periods without the need for constant replacements, making your presentations smoother and more efficient. The aluminum body not only gives it a sleek, professional look but also ensures durability and resilience against daily wear and tear.
The inclusion of a green laser pointer allows for clear visibility against various backgrounds, ensuring your points are highlighted effectively. With a maximum operating distance of 30 m, move freely around the room to engage with your audience without losing control of your slides. Moreover, the 2.4 GHz wireless technology ensures a stable connection, providing peace of mind that your presentation will go off without a hitch. This DICOTA presentation remote control is the perfect tool for professionals seeking reliability and performance in their presentation equipment.
  • Efficient power management
    Equipped with a rechargeable battery, this device ensures long-lasting performance and eliminates the need for frequent replacements, making it both convenient and eco-friendly.
  • Robust construction
    Crafted from aluminum, the body of this product not only offers a sleek, modern appearance but also provides durability, ensuring it can withstand the rigors of daily use.
  • Advanced presentation control
    Featuring a green laser pointer and a maximum operating distance of 30 m, this presentation remote control enhances the effectiveness of any presentation, allowing for seamless control from anywhere in the room.
  • Reliable connectivity
    Utilizes 2.4 GHz wireless technology to offer stable and reliable connectivity, ensuring uninterrupted control during presentations without the need for direct line of sight.
DICOTA presentation remote control - silver
Presentation remote control
Enclosure Colour
Silver
2.5 cm x 1.33 cm x 13.4 cm
Wireless Technology
2.4 GHz
Max Operating Distance
30 m
Rechargeable
2.5 cm
1.33 cm
13.4 cm
Enclosure Colour
Silver
Enclosure Material
Aluminium
Wireless Technology
2.4 GHz
30 m
Green laser pointer
Rechargeable
Brand: Dicota
