Dicota Wired Mouse
Dicota Wired Mouse
Quicklinx: HGB7WS00 Mfr#: D32011
Type: Mouse
Wired / Wireless: Wired
Colour: Black
£5.01 ex VAT
£6.01 inc VAT
The wired mouse with USB cable for everyone who needs to be able to work anywhere.
With the precise 1,200 dpi sensor you can complete even the most demanding tasks in no time at all. There is no need to install any additional software, as the mouse works with USB Plug & Play. The USB cable has to be plugged into the notebook or computer and the mouse is ready to start within a few seconds. Suitable for left-handers as well as right-handers, even for hours of use.
1200 dpi
User-friendly and quick installation thanks to USB cable
USB Plug & Play - no additional software required
For use in the office, at home or on business travel
Suitable for right- and left-handed
3 buttons; left/right-click, scroll-wheel with middle click.
  • Ergonomic design
    Designed for both right- and left-handed users, this mouse offers an inclusive, ergonomic experience ensuring comfort for long hours of use.
  • Precise navigation
    Equipped with laser movement detection technology and a 1200 DPI resolution, it provides precise and smooth cursor control for a variety of tasks.
  • Easy connectivity
    Featuring a simple Plug-and-Play setup with USB connectivity, this mouse is ready to use right out of the box without the need for additional software installations.
DICOTA - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.5 cm x 11.4 cm x 3.6 cm
60 g
Movement Detection Technology
Laser
Buttons Qty
3
Movement Resolution
1200 dpi
Mouse
Orientation
6.5 cm
11.4 cm
3.6 cm
60 g
Product Material
Plastic
Input Device
Wired
USB
Laser
Buttons Qty
3
Movement Resolution
1200 dpi
Plug and Play
Type: Mouse
Colour: Black
Brand: Dicota
