The DICOTA Webcam Tripod is designed to meet the needs of video creators, offering a blend of functionality and convenience. Its adjustable height and tilt capabilities allow for easy customization to capture the perfect shot, while the ball-type tripod head ensures smooth transitions and precise positioning. Whether used on a desktop for streaming or handheld for dynamic shooting angles, this tripod supports a wide range of webcams, making it a versatile addition to any video setup. Constructed from durable plastic, it combines lightweight portability with the stability needed to keep your device secure in any setting.
Versatile placement options
With both desktop and handheld placing options, this tripod offers flexibility in setup, ensuring you can capture the perfect angle whether you're at your desk or on-the-move. -
Adjustable design
Featuring adjustable height and tilt, this tripod allows for precise positioning, making it easier to achieve the best framing and focus for your webcams. -
Durable construction
Crafted from high-quality plastic, the DICOTA Webcam Tripod promises durability and stability, ensuring your device remains securely in place during use.
- DICOTA Webcam Tripod tripod
- Product Type
- Tripod
- 4.8 cm x 3.2 cm x 24.5 cm
- Black
- Placing / Mounting
- Desktop, handheld
- Head Type
- Ball
- Tripod Operating Height
- 14.7 cm - 24.5 cm
- 2-year warranty
- Product Type
- Tripod
- 4.8 cm
- 3.2 cm
- 24.5 cm
- Black
- Material
- Plastic
Tripod
- Desktop, handheld
- Max Operating Height
- 24.5 cm
- Min Operating Height
- 14.7 cm
- Supported Devices
- Webcam
- Adjustable height, adjustable tilt
Head
- Head Type
- Ball
- Limited warranty - 2 years
