Dicota Webcam Tripod
Quicklinx: HQ0SWS00 Mfr#: D32049
17 In Stock
£7.64 ex VAT
£9.16 inc VAT
The DICOTA Webcam Tripod is designed to meet the needs of video creators, offering a blend of functionality and convenience. Its adjustable height and tilt capabilities allow for easy customization to capture the perfect shot, while the ball-type tripod head ensures smooth transitions and precise positioning. Whether used on a desktop for streaming or handheld for dynamic shooting angles, this tripod supports a wide range of webcams, making it a versatile addition to any video setup. Constructed from durable plastic, it combines lightweight portability with the stability needed to keep your device secure in any setting.
  • Versatile placement options
    With both desktop and handheld placing options, this tripod offers flexibility in setup, ensuring you can capture the perfect angle whether you're at your desk or on-the-move.
  • Adjustable design
    Featuring adjustable height and tilt, this tripod allows for precise positioning, making it easier to achieve the best framing and focus for your webcams.
  • Durable construction
    Crafted from high-quality plastic, the DICOTA Webcam Tripod promises durability and stability, ensuring your device remains securely in place during use.
DICOTA Webcam Tripod tripod
Tripod
4.8 cm x 3.2 cm x 24.5 cm
Placing / Mounting
Desktop, handheld
Head Type
Ball
Tripod Operating Height
14.7 cm - 24.5 cm
Tripod
4.8 cm
3.2 cm
24.5 cm
Material
Plastic
Tripod
Placing / Mounting
Desktop, handheld
Max Operating Height
24.5 cm
Min Operating Height
14.7 cm
Supported Devices
Webcam
Adjustable height, adjustable tilt
Head
Head Type
Ball
Brand: Dicota
