Dicota Webcam Ringlight 5MP
Quicklinx: HQFHWS00 Mfr#: D32066
Hurry, only 3 left in stock!
£51.18 ex VAT
£61.41 inc VAT
The DICOTA Ringlight webcam is designed to enhance your video calling and content creation experience. With a high-resolution sensor capturing 5,000,000 pixels and a maximum digital video resolution of 2592 x 1944, every detail is presented in clear clarity. The integrated 3-level ring light ensures you can adjust the lighting to match your environment, providing flexibility and enhancing your appearance on screen. Audio is just as important as video, and with built-in dual digital microphones, your voice will be captured with clear quality. Whether you're in a conference call, streaming, or recording, the DICOTA Ringlight ensures you're seen and heard in high quality. Setup is straightforward, thanks to its Plug-and-Play compliance and USB 2.0 interface, complemented by an integrated 1.5 m USB-A cable for easy connectivity. This webcam is an enhancement to your digital interactions, offering a blend of performance, convenience, and quality.
  • Enhanced clarity
    With a total of 5,000,000 pixels and a max digital video resolution of 2592 x 1944, this webcam delivers exceptionally clear images, making every video call and broadcast look professional.
  • Versatile lighting
    Equipped with a 3-level ring light, the DICOTA Ringlight webcam ensures you're seen in the best light, no matter the environment. This feature allows for adjustments to find the perfect brightness for any situation.
  • Superior audio quality
    Featuring built-in dual digital microphones, this webcam captures your voice in clear quality, ensuring you're heard as well as seen during any conversation or recording.
  • Easy connectivity
    Thanks to its Plug-and-Play compliance and USB 2.0 interface, setting up the DICOTA Ringlight is a breeze. The integrated 1.5 m USB-A cable provides ample length for flexible positioning.
DICOTA Ringlight - webcam
Webcam - fixed
Audio
Yes: built-in dual digital microphones
4.78 cm x 5.45 cm x 7.97 cm
100 g
Wired
Camera
Max Resolution
2592 x 1944
Optical Sensor Type
5 MP
USB 2.0
USB-A cable - integrated - 1.5 m
3-level ring light, Auto Focus, plastic housing
Webcam
Audio Support
Wired
4.78 cm
5.45 cm
7.97 cm
100 g
Camera
Colour - fixed
Max Digital Video Resolution
2592 x 1944
Digital Video Capture Resolution
2592 x 1944
Image Sensor
5 MP
Computer Interface
USB 2.0
Plug and Play
Windows, Apple MacOS
