The DICOTA Ringlight webcam is designed to enhance your video calling and content creation experience. With a high-resolution sensor capturing 5,000,000 pixels and a maximum digital video resolution of 2592 x 1944, every detail is presented in clear clarity. The integrated 3-level ring light ensures you can adjust the lighting to match your environment, providing flexibility and enhancing your appearance on screen. Audio is just as important as video, and with built-in dual digital microphones, your voice will be captured with clear quality. Whether you're in a conference call, streaming, or recording, the DICOTA Ringlight ensures you're seen and heard in high quality. Setup is straightforward, thanks to its Plug-and-Play compliance and USB 2.0 interface, complemented by an integrated 1.5 m USB-A cable for easy connectivity. This webcam is an enhancement to your digital interactions, offering a blend of performance, convenience, and quality.
                Enhanced clarityWith a total of 5,000,000 pixels and a max digital video resolution of 2592 x 1944, this webcam delivers exceptionally clear images, making every video call and broadcast look professional.
                Versatile lightingEquipped with a 3-level ring light, the DICOTA Ringlight webcam ensures you're seen in the best light, no matter the environment. This feature allows for adjustments to find the perfect brightness for any situation.
                Superior audio qualityFeaturing built-in dual digital microphones, this webcam captures your voice in clear quality, ensuring you're heard as well as seen during any conversation or recording.
                Easy connectivityThanks to its Plug-and-Play compliance and USB 2.0 interface, setting up the DICOTA Ringlight is a breeze. The integrated 1.5 m USB-A cable provides ample length for flexible positioning.
- DICOTA Ringlight - webcam
- Webcam - fixed
- Audio
- Yes: built-in dual digital microphones
- 4.78 cm x 5.45 cm x 7.97 cm
- 100 g
- Black
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2592 x 1944
- Optical Sensor Type
- 5 MP
- USB 2.0
- Cables Included
- USB-A cable - integrated - 1.5 m
- 3-level ring light, Auto Focus, plastic housing
- 2-year warranty
- Webcam
- Audio Support
- Wired
- 4.78 cm
- 5.45 cm
- 7.97 cm
- 100 g
Camera
- Colour - fixed
- Max Digital Video Resolution
- 2592 x 1944
- Digital Video Capture Resolution
- 2592 x 1944
Image Sensor
- 5 MP
- Computer Interface
- USB 2.0
- Cables Included
- Plug and Play
- Black
- OS Required
- Windows, Apple MacOS
- Limited warranty - 2 years
