Dicota Webcam PRO Plus 4K
Quicklinx: GQ4ZWS00 Mfr#: D31888
More than 50 In Stock
£43.13 ex VAT
£51.75 inc VAT
The webcam offers razor-sharp images thanks to the 4K resolution. The automatic white balance and the autofocus function ensure that the webcam creates high-quality video recordings despite low light conditions. The integrated dual digital microphone ensures that conversations always sound natural and are easy to understand.
Attach the camera with the adjustable clip where it fits best - on a screen, notebook or on the tabletop - or remove the clip and screw the webcam onto your own tripod. An installation of additional software or additional drivers is not necessary, as the camera works with Plug & Play. So the integrated USB cable (1.5m) of the camera must simply be plugged into the notebook or computer and the webcam is ready to start in a few seconds. Camera cover to protect privacy. The webcam has wide software compatibility, which is compatible with all popular video chat programs. Compatible with Mac, Windows and other USB-C supported devices.
  • 4K resolution (3840 × 2160p)
  • Plug & Play, no additional software required
  • Integrated dual digital microphone
  • Autofocus
  • Automatic white balance
  • USB 2.0: compatible with common devices with USB port (1.5m, included)
  • Camera cover to protect privacy
  • Can be used on the desktop, on the table or with a tripod
  • Swivel up / down, 360° rotatable
  • 4K/30 frames per second or 1080p/60 frames per second
  • 110° field of view
  • Compatible with Microsoft and macOS
  • Works with all popular video chat programs
DICOTA Webcam PRO Plus 4K - webcam
Webcam
Audio
Yes: built-in dual stereo microphones
10.6 cm x 5.7 cm x 5.35 cm
125 g
Wired
Camera
Max Resolution
3840 x 2160
Video Modes
2160p
Focus Adjustment
Automatic
USB 2.0
1 - USB cable - 1.5 m
Plastic housing, auto white balance, 110° field of view
Webcam
Audio Support
Wired
10.6 cm
5.7 cm
5.35 cm
125 g
Camera
Max Digital Video Resolution
3840 x 2160
Video Modes
2160p
Digital Video Capture Resolution
3840 x 2160
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
1 x USB cable - 1.5 m
Plug and Play
Brand: Dicota
