Dicota USB-C to HDMI Mini Adapter with PD (4k/100W)
Quicklinx: HQ0VWS00 Mfr#: D32047
22 In Stock
£13.90 ex VAT
£16.68 inc VAT
Discover the perfect solution for connecting and charging your devices with the DICOTA video adapter. This high-quality cable features 4K60Hz support, allowing you to enjoy high-definition visuals on your monitor or TV. With USB Power Delivery up to 100 W, it not only ensures your devices stay connected but also charged, eliminating the need for multiple cables. The adapter's durable metal housing ensures longevity, making it a reliable choice for everyday use. Whether you're setting up a professional workstation or a home entertainment system, this adapter offers the versatility and performance you need.
  • High-resolution support
    Experience crystal-clear visuals with the adapter's support for a maximum output resolution of 3840 x 2160, ensuring your displays look stunning at 4K60Hz.
  • Versatile connectivity
    Equipped with both 24-pin USB-C and 19-pin HDMI Type-A connectors, this video adapter offers flexible connection options to a wide range of devices, making it easy to set up your ideal workstation or entertainment setup.
  • Durable design
    The adapter features a robust metal housing, designed to withstand the rigors of daily use while ensuring reliable performance and longevity.
  • Power delivery
    With USB Power Delivery support up to 100 W, this adapter not only connects your devices but also charges them simultaneously, keeping your workspace clutter-free and your devices powered.
DICOTA adapter
Cable
Adapter
Max Output Resolution
3840 x 2160 - 60 Hz
Silver
Connectors
24 pin USB-C - male
Connectors (Second End)
24 pin USB-C - female , HDMI - female
USB Power Delivery (100W), 4K60Hz support
Cable Type
Adapter USB Power Delivery (100W), 4K60Hz support
Metal housing
Silver
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male
24 pin USB-C - female , 19 pin HDMI Type A - female
4.08 cm
1.15 cm
2.44 cm
10 g
Brand: Dicota
