Dicota USB-C to Ethernet Mini Adapter with PD (100W)
Quicklinx: HQ0ZWS00 Mfr#: D32048
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Type: Network adapter
29 In Stock
£15.32 ex VAT
£18.38 inc VAT
The DICOTA network adapter is a performance-oriented device designed to meet the connectivity needs of professionals and businesses. With its RJ-45 and 24-pin USB-C connectors, it offers versatile network integration options, including Ethernet 1000Base-T, 100Base-TX, and 10Base-T. This adapter is built for speed, supporting Ethernet, Fast Ethernet, and Gigabit Ethernet data link protocols to ensure that your data transfer is both swift and efficient. Furthermore, its compliance with USB Power Delivery standards means it can manage power effectively, making it a smart choice for any setup. The adapter's external form factor and compatibility with USB-C and Thunderbolt 3 interfaces make it incredibly easy to connect to a wide range of devices. Additionally, its durable metal housing not only adds a professional look to your workspace but also ensures the adapter's longevity. Whether you're looking to upgrade your home office or equip a corporate environment, the DICOTA network adapter offers a reliable and efficient solution for your networking needs.
  • Robust connectivity
    Experience seamless network integration with the DICOTA network adapter, offering a wide range of connectivity options including Ethernet 1000Base-T, 100Base-TX, and 10Base-T. Its external form factor and USB-C / Thunderbolt 3 interface ensure easy connection to a variety of devices.
  • High-speed data transfer
    Designed for performance, this adapter supports Ethernet, Fast Ethernet, and Gigabit Ethernet data link protocols, enabling swift and efficient data transfer across your network.
  • Durable design
    The metal housing of the DICOTA network adapter not only provides a sleek, professional look but also ensures durability and longevity, making it a reliable choice for any setup.
DICOTA - network adapter - USB-C / Thunderbolt 3 - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
Ports
2.48 cm x 4.46 cm x 1.42 cm
10 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Silver
Network adapter
External
Ports
Wired
Cabling Type
Metal housing
1 x 1000Base-T - RJ-45 - female , 1 x USB (power only) - 24 pin USB-C (100 Watt passthrough) - female
USB Power Delivery
Silver
2.48 cm
4.46 cm
1.42 cm
10 g
Protocol: Ethernet
Protocol: Gigabit Ethernet
Brand: Dicota
