The design of notebooks has evolved steadily over the years. Always lighter, thinner and more agile. Comfortable to carry, comfortable to use. However, most trendsetters no longer offer enough USB ports to connect all peripheral devices.
Expand the USB connection of your computer using the integrated USB-C connector. The DICOTA hub is compatible with Mac, Windows and other USB-C supported devices. Thanks to the plug and play specification, you don't need additional device configuration. The first USB-A - left to right - supports both, Battery Charging (BC1.2) with power up to 7.5W and data transmission. The second USB-A supports data transmission up to 5Gbps and charge for the connected USB device. The first USB-C supports up to 5Gbps data transmission and charge for the connected USB device, and the USB-C PD3.0 - the one on the right side -, supports up to 5Gbps as downstream data port or up to 100W Power Delivery charging as upstream charging port. Its compact size makes it ideal for the home office or environments where a clean productive desktop is needed.
- DICOTA USB-C Portable Hub 4-in-1 - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 2 x USB-C + 2 x SuperSpeed USB
- 9 cm x 6 cm x 1.57 cm
- 57 g
- White
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 1 x USB-C (power delivery) Type C , 1 x USB-C Type C , 2 x USB 3.0 Type A
- White
- Cables Included
- 1 x USB-C cable - 15 cm
- Plug and Play
- 9 cm
- 6 cm
- 1.57 cm
- 57 g
- Limited warranty - 2 years
