Dicota USB-C Portable 5-in-1 Docking Station 4K HDMI/DP PD 100W
Quicklinx: HQ19WS00 Mfr#: D32064
More than 50 In Stock
£26.87 ex VAT
£32.24 inc VAT
The design of notebooks has evolved steadily over the years. Always lighter, thinner and more agile. Comfortable to carry, comfortable to use. However, most trendsetters no longer offer enough ports to connect all peripheral devices. The DICOTA USB-C unit is the solution. Enjoy maximum productivity everywhere you go.
Expand the USB connection of your computer using the integrated USB-C connector. With the HDMI (4K/30Hz) port you can connect this Hub to a monitor with high resolution. The RJ-45 LAN port with up to 1000Mbps enable to connect computers onto Ethernet networks. The Multi Hub also offers 1xUSB-C Power Delivery up to 100 W and 3xUSB-A 3.0 ports. SD and microSD card readers are integrated for transferring files with devices such as cameras. The unit is compatible with Mac, Windows and other USB-C supported devices. Thanks to the plug and play specification, you don't need additional device configuration.
DICOTA 5-in-1 - docking station - USB-C - HDMI, DP
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, DP
8 cm x 4.75 cm x 1.45 cm
70 g
Silver
Docking station
8 cm
4.75 cm
1.45 cm
70 g
Enclosure Colour
Silver
Video
Max Resolution Details
4K (HDMI) , 4K (DisplayPort and HDMI simultaneously) , 1080P (VGA only)
1 x USB-C with Power Delivery - 24 pin USB-C , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x video - VGA - 15 pin D-Sub (DB-15) , 1 x USB-A - 4 pin USB Type A
1 x USB-C cable
100W power delivery, portable
Plug and Play
Apple MacOS, Microsoft Windows
Brand: Dicota
