Discover the power of seamless connectivity with the DICOTA Docking Station. Designed for professionals who demand efficiency and versatility, this port expansion solution transforms your workspace into a dynamic environment. With its USB-C cable, you can connect to a variety of devices, including SD and microSD card readers, ensuring that data transfer is never a bottleneck in your productivity. The docking station supports 4K HDMI output, enabling you to enjoy high-definition visuals at a 30 Hz refresh rate. Whether you're presenting in a meeting or working on graphics-intensive projects, the clarity and detail are impressive. Additionally, the docking station is equipped with three USB-A 3.0 ports, providing ample connectivity for your peripherals and ensuring fast data transfer speeds. The inclusion of a 10/100/1G Ethernet port offers reliable network connections, essential for seamless online collaboration. One of the standout features is the 100 W power delivery through USB-C, which ensures your devices are charged efficiently, keeping you operational throughout the day. Encased in a durable aluminum housing, this docking station is not only built to last but also to complement your workspace with its sleek design. It's portable, too, making it an excellent choice for professionals on-the-move. Elevate your productivity and connectivity with the DICOTA Docking Station, a comprehensive solution that meets the demands of modern professionals.
Versatile connectivity
Equipped with a 24-pin USB-C connector, this docking station offers a wide range of connectivity options including HDMI, USB-A 3.0, and Ethernet interfaces, making it an ideal solution for various data transfer and display needs. -
High-definition output
Supports 4K resolution at a 30 Hz refresh rate through the HDMI interface, providing clear and vibrant visuals for an enhanced viewing experience on external displays. -
Enhanced power delivery
Features 100 W power delivery through USB-C, allowing you to charge your devices quickly while maintaining a high level of productivity. -
Durable design
The aluminum housing not only gives the docking station a sleek, modern look but also ensures durability and portability, making it perfect for professionals on-the-go.
 - DICOTA - docking station - USB-C - HDMI
- Product Type
 - Docking station
- Docking Interface
 - USB-C
- Video Interfaces
 - HDMI
 - 10.17 cm x 1.58 cm x 4.33 cm
 - 70 g
 - Silver
 - 2-year warranty
- Product Type
 - Docking station
 - 10.17 cm
 - 1.58 cm
 - 4.33 cm
 - 70 g
- Enclosure Colour
 - Silver
Video
- Max Resolution Details
 - 4K - 30 Hz (HDMI)
 - 1 x USB-C with Power Delivery - 24 pin USB-C , 1 x audio / video - HDMI - 19 pin HDMI Type A , 3 x USB-A 3.0 - 4 pin USB Type A , 1 x network - 10/100/1G Ethernet - RJ-45
- Input Device
 - SD card reader, microSD card reader
- Cables Included
 - 1 x USB-C cable
 - 100W power delivery, portable, aluminium housing
 - Limited warranty - 2 years
