Dicota USB-C 4-in-1 Highspeed Hub 10 Gbps
Quicklinx: HQ11WS00 Mfr#: D32061
Ports: 4
More than 50 In Stock
£15.61 ex VAT
£18.73 inc VAT
The DICOTA hub is a high-speed, 4-in-1 USB C device designed to meet the connectivity needs of modern tech environments. With its four ports, including two USB-C 3.2 Gen 2 and two USB 3.2 Gen 2, it offers versatile connection options for a wide range of devices. The hub supports data transfer rates of up to 10 Gbps, enabling efficient file transfers and device management. Constructed with a durable aluminum housing, it ensures reliability and longevity, making it a smart investment for both home and office use. Additionally, its compliance with Plug-and-Play standards means setup is straightforward, requiring no additional software or drivers. Whether for professional or personal use, the DICOTA hub enhances productivity by providing a stable, high-speed connection platform for all your peripherals.
  • Efficient connectivity
    The DICOTA hub offers a seamless connection experience with two USB-C 3.2 Gen 2 ports and two USB 3.2 Gen 2 ports, ensuring high-speed data transfer rates of up to 10 Gbps. This feature allows for efficient multitasking and data management across multiple devices.
  • Durable design
    Built with an aluminum housing, this hub is designed for durability and long-term use. The robust material protects the internal components, making it a reliable choice for everyday connectivity needs.
  • Plug-and-play convenience
    Compliant with Plug-and-Play standards, the DICOTA hub simplifies the setup process, allowing for immediate use without the need for additional drivers or software installations. This feature ensures a user-friendly experience for all.
  • Versatile compatibility
    Featuring a combination of USB-C and Type-A connectors, this hub is designed to accommodate a wide range of devices, making it a versatile addition to any tech setup. Its desktop form factor further enhances its utility by providing a stable base for operation.
DICOTA - hub - 10 Gbps, 4-in-1 USB C, highspeed - 4 ports
Hub - 4 ports
Subtype
USB
Ports
2 x USB-C 3.2 Gen 2 + 2 x USB 3.2 Gen 2
Aluminium housing
USB 3.2 Gen 2
11 cm x 3.5 cm x 1.29 cm
50 g
Silver
Apple MacOS, Microsoft Windows
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Aluminium housing
USB 3.2 Gen 2
2 x USB 3.2 Gen 2 Type A , 2 x USB 3.2 Gen 2 Type C
Silver
1 x USB-C cable
Plug and Play
11 cm
3.5 cm
1.29 cm
50 g
Ports: 4
Brand: Dicota
