Dicota USB-C 10-in-1 Interface and Charging Hub 4K PD 100W
Quicklinx: HQ1BWS00 Mfr#: D32059
£29.62 ex VAT
£35.54 inc VAT
Discover a solution for expanding your device's connectivity with the DICOTA Docking Station. This port expansion tool is designed to meet the needs of professionals and tech enthusiasts alike, offering a wide array of connections including HDMI, VGA, USB-A 3.0, and Ethernet ports. With its 4K HDMI output, you can enjoy crisp, clear visuals at a 30 Hz refresh rate, perfect for presentations, streaming, or multitasking on multiple displays.
The docking station also features 100 W power delivery through its USB-C port, allowing you to charge your devices quickly and efficiently, eliminating the need for multiple chargers. Its compact, aluminum housing not only adds a touch of elegance to your workspace but also ensures durability and portability, making it an ideal companion for business trips or remote work. Additionally, the inclusion of both SD and microSD card readers offers convenient access to files and media, enhancing your productivity and workflow. Elevate your connectivity and streamline your setup with the DICOTA Docking Station.
  • Versatile connectivity
    Equipped with a wide range of ports including HDMI, VGA, USB-A 3.0, and more, this docking station ensures compatibility with a multitude of devices and peripherals, offering seamless integration into any workspace.
  • High-definition output
    Supports 4K resolution through HDMI at a 30 Hz refresh rate, providing crisp, clear visuals for an enhanced viewing experience on compatible displays.
  • Enhanced power delivery
    Features 100 W power delivery via USB-C, allowing for the charging of connected devices without the need for an additional power source, making it an ideal solution for mobile professionals.
  • Compact and durable design
    The aluminum housing not only gives it a sleek, professional look but also provides durability, making it portable and robust for business travels or remote work setups.
  • Comprehensive card reading capabilities
    Includes both SD and microSD card readers, facilitating easy access to files and media from a variety of memory cards, enhancing productivity and data management.
DICOTA - docking station - USB-C - VGA, HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
10 cm x 1.7 cm x 5.5 cm
120 g
Silver
Docking station
10 cm
1.7 cm
5.5 cm
120 g
Enclosure Colour
Silver
Video
Max Resolution Details
4K - 30 Hz (HDMI)
1 x USB-C with Power Delivery - 24 pin USB-C , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x audio / video - VGA , 2 x USB-A 3.0 - 4 pin USB Type A , 1 x microphone / audio - 3.5mm audio jack , 1 x network - 10/100/1G Ethernet - RJ-45
Input Device
SD card reader, microSD card reader
1 x USB-C cable
100W power delivery, portable, aluminium housing
Brand: Dicota
