Dicota Universal Security Cable Lock, 3 Exchangeable heads Masterke
Quicklinx: FS4TWS00 Mfr#: D31700
£23.36 ex VAT
£28.03 inc VAT
A notebook can be stolen in an instant. Expensive hardware and important data are lost. This can involve a lot of work and great expense. Police, insurance, data recovery etc. Targeted prevention is the answer - with a quality lock from DICOTA. Easy, convenient and effective. Ideal for use in open-plan offices, public areas, or while travelling.
Currently device manufacturers use three different lock slot formats. Thanks to the Security Lock with Exchangeable T/N/W Head your lock will suit all kinds of devices equipped with an anti-theft port. Notebooks as well as projectors, monitors and printers can be effectively secured with the DICOTA locking system. The T-Lock head is for 3 x 7 mm slots, the W for 3.2 x 4.5 mm slots, and the N for 2.5 x 6 mm slots. Long-lasting. Thanks to the easy-exchange heads, you will be able to change your devices in the future and still use the security lock. Enjoy high flexibility in workplace design thanks to the 360° rotatable cylinder. Thanks to the push-to-lock function, the lock can be secured without a key using one hand. It's quick, simple and reliable. The sheathed multi-strand steel cable is 2 m long and extra strong with a diameter of 4.4 mm. The functional Velcro strap allows the cable to be rolled up for compact storage and transportation. Two keys are included as standard.
DICOTA - security cable lock
Security cable lock
Package Content
2 x keys
Anthracite
Product Material
Plastic, steel
Length
2 m
110 g
Touch fastener, push-to-lock, 360° head rotation, 4.4 mm diameter, exchangeable T/N/W head
Security cable lock
Product Material
Plastic, steel
Package Content
2 x keys
Length
2 m
110 g
Anthracite
Limited warranty: - 2 years
Brand: Dicota
