Dicota Universal Security Cable Lock - 3 Exchangeable heads fits all slots - Keyed
Quicklinx: FC3KWS00 Mfr#: D31699
Hurry, only 1 left in stock!
£23.94 ex VAT
£28.72 inc VAT
Currently device manufacturers use three different lock slot formats. Thanks to this Universal Security Cable Lock with exchangeable heads your lock will suit all kinds of devices equipped with an anti-theft port. Notebooks as well as projectors, monitors and printers can be effectively secured with the DICOTA locking system. The T-Lock head is for 3 x 7 mm slots, the Wedge for 3.2 x 4.5 mm slots, and the Nano for 2.5 x 6 mm slots*.
Long-lasting. Thanks to the easy-exchange heads, you will be able to change your devices in the future and still use the security lock. Thanks to the push-to-lock function, the lock can be secured without a key using one hand. It's quick, simple and reliable. The sheathed multi-strand steel cable is 2 m long and extra strong with a diameter of 4.4 mm. The functional Velcro strap allows the cable to be rolled up for compact storage and transportation. Two keys are included as standard. This lock is a standalone version and cannot be integrated into a larger locking system. *Wedge®, T-Bar™ and Nano Security Slot™ are trademarks of a third party without a connection to DICOTA SCHWEIZ AG.
  • Suitable for all devices thanks to the 3 exchangeable heads (T-Lock, Wedge and Nano)
  • PVC coated multi-strand steel cable, 2 m in length
  • Maximum theft-protection thanks to 4.4 mm cable diameter
  • Flexible workplace design thanks to the 360° rotatable and 90° swiveling closing head
  • Easy installation with push-to-lock function
  • Two keys are included as part of the delivery
  • Functional Velcro strap for compact storage and transportation
  • Three spacers supplied to ensure seamless fit for different models (0.4 mm)
  • Enhanced security
    The Security Lock Exchangeable T/N/W Head by DICOTA offers a high level of protection for your devices. With its push-to-lock feature, securing your notebook or tablet becomes effortless and reliable. The combination of plastic and steel materials ensures durability and resilience against tampering.
  • Versatile compatibility
    Designed to meet the needs of a wide range of devices, this security cable lock is compatible with notebooks and tablet PCs. Its exchangeable T/N/W head system allows for flexible use across different models, making it a suitable security solution for both personal and professional environments.
DICOTA Security Lock Exchangeable T/N/W Head - security cable lock
Security cable lock
Package Content
2 x keys
Anthracite
Product Material
Plastic, steel
Length
2 m
110 g
Push-to-lock
Security cable lock
Product Material
Plastic, steel
Package Content
2 x keys
Length
2 m
110 g
Anthracite
Push-to-lock
Limited warranty: - 2 years
Brand: Dicota
