Dicota Universal Security Cable Lock - 3 Exchangeable heads fits all slots - Combination
Quicklinx: FC3JWS00 Mfr#: D31713
£23.66 ex VAT
£28.39 inc VAT
Targeted prevention is the answer. Thanks to this security cable lock with exchangeable head your lock will suit all kinds of devices equipped with an anti-theft T-Lock (T-Bar), Wedge or Nano slot. Easy, convenient and effective. No key and no compromise on security: easily set your individual 4-digit numeric code out of 10,000 possible combinations. Notebooks as well as projectors, monitors and printers can be effectively secured with the 3-way exchangeable heads.
Use the T-Lock head for 3 x 7 mm slots, the Wedge for 3.2 x 4.5 mm slots and the Nano for 2.5 x 6 mm slots. Compatible with the slim Noble Wedge® Security Slot, the Kensington® Security Slot for T-Bar™ and the slim Kensington Nano Security Slot™*. Long-lasting solution. Thanks to the easy-exchange heads, you will be able to change your devices in the future and still use the security lock. Quick, simple and reliable. Enjoy high flexibility in workplace design thanks to the 90° rotatable head and 360° rotatable cylinder. It's quick, simple and reliable. The sheathed multi-strand steel cable is 2 m long and extra strong with a diameter of 4.4 mm. The functional Velcro strap allows the cable to be rolled up for compact storage and transportation. This lock is a standalone version and cannot be integrated into a larger locking system. *Noble Wedge®, Kensington®, T-Bar™ and Kensington Nano Security Slot™ are trademarks of a third party without a connection to DICOTA SCHWEIZ AG.
  • Suitable for all devices thanks to the 3 exchangeable heads (T-Lock, Wedge and Nano)
  • 4-digit numeric code adjustable individually out of 10,000 combinations
  • PVC coated multi-strand steel cable, 2 m in length
  • Maximum theft-protection thanks to 4.4 mm cable diameter
  • Flexible workplace design thanks to the 90° head pivot and 360° rotatory cylinder
  • Functional Velcro strap for compact storage and transportation
  • Three spacers supplied to ensure seamless fit for different models (0.4 mm)
  • Enhanced security
    The 4-digit code feature offers personalized security, ensuring that your device remains safe from unauthorized access.
  • Durable design
    Crafted from steel and thermoplastic rubber, this security combination lock is built to withstand daily wear and tear, providing long-lasting protection for your devices.
DICOTA Security Combination Lock Exchangeable T/N/W Head - security cable lock
Security cable lock
Product Material
Steel, thermoplastic rubber
Length
2 m
130 g
Combination lock, 4 digit code, 4.4 mm diameter
Security cable lock
Product Material
Length
2 m
130 g
Limited warranty: - 2 years
Brand: Dicota
