Dicota Universal Notebook Charger USB-C UK
Quicklinx: DR0ZWS00 Mfr#: D31433
With the DICOTA Universal Notebook Charger USB-C you will experience pure mobility and have the right connector with you anytime. Notebooks, tablets, smartphones and accessories - over 4 USB-A ports and one USB-C port with Power Delivery 2.0 you can charge up to 5 devices simultaneously with one single power supply unit. The 7 included notebook connection tips ensure full connectivity for various models of the most popular manufacturers: Acer, ASUS, Dell, Fujitsu, HP, Lenovo, Microsoft Surface, Samsung, Toshiba and more.
Thanks to the Qualcomm Quick Charge 3.0 Technology, long waiting times are a thing of the past. Charge your battery up to 4 times faster than with traditional adapters. After only 5 minutes of charging your Qualcomm-ready device will have enough power for 5 hours of mobile usage. The output voltage (5 - 20 V) and the charging current (up to 3.5 A) adapt themselves automatically to the connected devices. The intelligent control system preserves your battery and at the same time offers reliable protection against over current, over voltage, short circuit and overheating. Elegant design, compact shape and only 240 grams in weight - the perfect companion for fast and efficient energy at home, in the office or on the road.
  • Experience pure mobility with one singly power supply unit -
  • for notebooks, tablets, smartphones and other devices
  • 1 x USB-C output with Power Delivery 2.0
  • 4 x USB-A output with Qualcomm Quick Charge 3.0 technology
  • 7 notebook connection tips for various models: Acer, ASUS, Dell, Fujitsu, HP, Lenovo, Microsoft Surface, Samsung, Toshiba and more
  • Efficient and preservative charging with 80 W output-power
  • Output voltage (5 - 20 V) and charging current (up to 3.5 A) adapt themselves automatically to the connected devices
  • Protection against over current, over voltage, short circuit and over-temperature
  • Elegant design, compact shape and only 240 grams in weight
DICOTA Universal Notebook Charger USB-C - power adapter - 80 Watt
Power adapter - external
240 g
United Kingdom
Output Voltage
5 - 20 V
Power Capacity
80 Watt
Output connectors
4 x 4 pin USB Type A , 1 x 24 pin USB-C
7 notebook power tips
White
11 cm x 9.8 cm x 2 cm
White
United Kingdom
Output Voltage
5 - 20 V
Power Capacity
80 Watt
Power cable
Over current protection, over voltage protection, short-circuit protection, thermal protection, Qualcomm Quick Charge 3.0
Power Delivery 2.0
11 cm
9.8 cm
2 cm
240 g
