Charge fast, secure and store multiple devices. With the universal charging cabinet, you will charge simultaneously up to 20 devices with built-in power supply. Suitable for MacBooks, Chromebooks, Ultrabooks, tablets, smartphones and other compatible devices. Choose USB-C or USB-A port and store the devices inside while charging. The LED indicators will show you the charging status from each port. Lock the door and keep secure the devices.
Thanks to the Qualcomm Quick Charge 3.0 Technology, long waiting times are a thing of the past. The vertical orientation allows easy access to your devices and the auto-sensing LED illumination will light the inside once the door is open. The ultraviolet light function makes the charging cabinet much safer and healthier as reduces the bacteria. Protected against overcurrent, overvoltage, short circuit and overheating. Easy to move due to its universal wheels, the charging cabinet could go anywhere. Long-term investment protection thanks to exchangeable charging cables.
- DICOTA cart - for 20 tablets / notebooks - white
- Product Type
- Cart - lockable
- 42.3 cm x 39.8 cm x 80.5 cm
- 36 kg
- Recommended Use
- 20 tablets / notebooks
- Material
- Iron
- White
- Wheels Qty
- 4
- 2-year warranty
- 42.3 cm
- 39.8 cm
- 80.5 cm
- 36 kg
- Material
- Iron
- White
AV Furniture
- Cart
- Recommended Use
- Cart Functionality
- Charge
- Lockable
- Wheels Qty
- 4
- Brakes Qty
- 4
- Lock Type
- Key
- Limited warranty - 2 years
