The protective sleeve encloses your device like a second skin. Best protection thanks to premium neoprene and fluffy synthetic fur lining. Comes with additional, comfortable carrying handle and storage compartment on the back.
The Ultra Skin PRO accompanies you reliably and provides custom-fitted protection for your 14-14.1" notebook or ultrabook. The especially lightweight case combines compact design with robust materials and functional details.
The material selection makes the Ultra Skin Plus PRO built to last. The case is made of durable neoprene combined with nylon and real leather details. A soft synthetic fur lining on the inside protects your notebook from scratches. The padded carrying handles ensure comfortable transportation, but can also be stored in a larger bag to save space. A zippered compartment on the back of the bag provides storage space for documents and mobile accessories. Power bank, charging cable and mobile phone are thus always in easy reach. The Ultra Skin Plus PRO is equipped with two zippers. This allows you to charge your notebook or ultrabook conveniently, without sacrificing maximum protection.
 - DICOTA Ultra Skin Plus PRO Laptop Sleeve 14.1" - notebook carrying case
- Product Type
 - Notebook carrying case
- Product Material
 - Neoprene
 - 37.5 cm x 26.4 cm x 1.3 cm
 - 300 g
- Notebook Compatibility
 - 14.1"
 - Scratch-proof, zippered, padded
- Carrying Strap
 - Hand strap
 - Limited lifetime warranty
- Product Type
- Product Material
 - Neoprene
 - 37.5 cm
 - 26.4 cm
 - 1.3 cm
 - 300 g
 - 14.1"
- Notebook Compatibility Dimensions
 - 35 cm x 24.5 cm x 3 cm
- Additional Compartments
 - Mobile phone, cable, documents, mobile accessories
- Carrying Strap
 - Hand strap
 - Limited warranty: - lifetime
