The universal GaN laptop charger is compatible with a wide range of devices including notebooks, tablets, smartphones and more, charging them quickly and safely. GaN technology enables higher efficiency and power density than conventional chargers, making the charger smaller, lighter and more powerful. With two USB-C outputs with Power Delivery 3.0 technology, the charger enables fast charging speeds with a maximum power of 100W, while the USB-A output with Qualcomm Quick Charge 4+ technology ensures fast charging. In addition to universal compatibility and fast charging performance, the charger offers reliable protection against over-current, over-voltage, short-circuit and overheating. An EU power supply and a UK power supply are included, ideal for travelling. Overall, the GaN charger provides fast and safe charging power for a wide range of devices and is the perfect choice for anyone looking for a reliable and compact charger on the move.
- DICOTA Universal PRO power adapter - GaN technology - 2 x USB-C, USB - 100 Watt
- Product Type
- Power adapter
- Designed For
- Laptop
- 6.9 cm x 3.2 cm x 6.7 cm
- 135 g
- White
- Output Connector Type
- Total 3: 2 x USB-C, USB
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Voltage Provided
- 5 / 9 / 12 / 15 / 20 V
- Max Electric Current
- 5 A
- Fast Charge Technology
- Power Delivery 3.0, Qualcomm Quick Charge 4.0+
- Power Provided
- 100 Watt
- Power Device Details
- 2 x - 24 pin USB-C , - 4 pin USB Type A
- Power Device Operating Mode
- PD (USB-C) 5/9/12/15/20 V - 3/3/3/3/5 A , USB-A 5/9/12 V - 3/2.2/1.5 A
- Cables
- USB-C cable
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Laptop
- 6.9 cm
- 3.2 cm
- 6.7 cm
- 135 g
- Enclosure Colour
- White
- Voltage Required
- Voltage Provided
- Output connectors
- Total 3: 2 x 24 pin USB-C, 4 pin USB Type A
- Power Provided
- 100 Watt
- 5 A
- 2 x 24 pin USB-C , 4 pin USB Type A
- Fast charging, detachable input connectors, overcharging protection, over voltage protection, short circuit protection, over-temperature protection, lightweight design, GaN Tech
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK)
- Cables Included
- USB-C cable
- Limited warranty - 2 years
