Dicota Travel Laptop GaN Charger Universal PRO 100W
Quicklinx: HG74WS00 Mfr#: D31983
More than 50 In Stock
£44.36 ex VAT
£53.23 inc VAT
The universal GaN laptop charger is compatible with a wide range of devices including notebooks, tablets, smartphones and more, charging them quickly and safely. GaN technology enables higher efficiency and power density than conventional chargers, making the charger smaller, lighter and more powerful. With two USB-C outputs with Power Delivery 3.0 technology, the charger enables fast charging speeds with a maximum power of 100W, while the USB-A output with Qualcomm Quick Charge 4+ technology ensures fast charging. In addition to universal compatibility and fast charging performance, the charger offers reliable protection against over-current, over-voltage, short-circuit and overheating. An EU power supply and a UK power supply are included, ideal for travelling. Overall, the GaN charger provides fast and safe charging power for a wide range of devices and is the perfect choice for anyone looking for a reliable and compact charger on the move.
DICOTA Universal PRO power adapter - GaN technology - 2 x USB-C, USB - 100 Watt
Power adapter
Laptop
6.9 cm x 3.2 cm x 6.7 cm
135 g
White
Output Connector Type
Total 3: 2 x USB-C, USB
AC 100-240 V (50/60 Hz)
Voltage Provided
5 / 9 / 12 / 15 / 20 V
Max Electric Current
5 A
Fast Charge Technology
Power Delivery 3.0, Qualcomm Quick Charge 4.0+
Power Provided
100 Watt
Power Device Details
2 x - 24 pin USB-C , - 4 pin USB Type A
Power Device Operating Mode
PD (USB-C) 5/9/12/15/20 V - 3/3/3/3/5 A , USB-A 5/9/12 V - 3/2.2/1.5 A
Cables
USB-C cable
Power adapter
Laptop
6.9 cm
3.2 cm
6.7 cm
135 g
Enclosure Colour
White
Voltage Provided
Output connectors
Total 3: 2 x 24 pin USB-C, 4 pin USB Type A
Power Provided
100 Watt
5 A
2 x 24 pin USB-C , 4 pin USB Type A
Fast charging, detachable input connectors, overcharging protection, over voltage protection, short circuit protection, over-temperature protection, lightweight design, GaN Tech
Power plug adapter (EU), power plug adapter (UK)
USB-C cable
Brand: Dicota
