Dicota Top Traveller Twin PRO Notebook Carrying Case 14-15.6" - Black
Quicklinx: DQZHWS00 Mfr#: D30844
Travel '1st class' with Top Traveler Twin PRO. The expandable toploader bag reliably accompanies you everywhere and meets the high standards of quality, functionality and protection: fit-all system holds notebooks of various sizes, anti-slip technology ensures your notebook and the shoulder strap do not slide and the light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. With the expandable compartment and two extra document compartments at the back, the bag provides generous storage for your documents, printer, projector and other mobile accessories.
The fit-all system separating wall in the notebook compartment lies protectively across your notebook and fits automatically. The perforated and thus light EVA foam material in the sealable notebook compartment perfectly protects the edges of your device with a remarkable saving in weight. The bag is light and comfortable in your hand thanks to the high-quality genuine leather handles. The anti-slip technology coating ensures perfect grip for your notebook in the compartment and the adjustable padded shoulder strap. Excellent protection for your tablet thanks to the EVA-shaped compartment with extra-soft nylex inner lining. Front pocket with keyring, storage for mobile accessories and insert pockets for your personal equipment. Zip compartment for IDs. Trolley strap can also be used as an additional document compartment. Bag bottom made from waterproof material. Address label - Dicota's attention to detail makes this bag one of your extremely reliable business partners!
DICOTA Top Traveller Twin PRO Laptop Bag 15.6" - notebook carrying case
Notebook carrying case
Product Material
Nylon, ethylene vinyl acetate (EVA)
41 cm x 20.5 cm x 30 cm
1.7 kg
Notebook Compatibility
15.6"
Waterproof, adjustable shoulder strap, zipper pocket, padded shoulder strap, slip pocket, molded
Carrying Strap
Hand grip, shoulder carrying strap
Product Material
41 cm
20.5 cm
30 cm
1.7 kg
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, power adapter, passport, documents, pens, wallet, business cards, mobile accessories, Apple iPad
Carrying Strap
