The bags Style convince through an exciting combination of high-quality Polyester materials. Another design highlight is the functional metal closure on the font side of the bag. There's double protection for your Surface device up to 15" in the lockable notebook compartment: with surrounding padding and reliable fastening thanks to the elastic strap. The generously sized main compartment offers plenty of storage space for documents and other luggage. Even your tablet up to 10.5" can be safely stored in the padded slip pocket. Place your power adapter and other equipment in the dedicated inner compartments to keep things organized. Within the front compartment with magnetic closure and functional dividers you have your smartphone, power bank, pens and other accessories to hand at all times. The length-adjustable shoulder strap with extra cushioning is attached diagonally for an ideal weight distribution. Moreover, the comfortably padded carry handles as well as the trolley fastening strap hidden on the back side of the bag ensure flexible use and guarantee a comfortable transportation.
- DICOTA Style - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 600D polyester
- 41 cm x 9 cm x 31 cm
- 780 g
- Notebook Compatibility
- 15"
- Notebook Supported Sizes
- Up to 15" / up to 38.1 cm
- Magnetic closure, adjustable length, padded slip pocket, elastic fixation straps, lockable notebook compartment, hidden trolley strap
- Carrying Strap
- Fastening clip, detachable padded shoulder strap
- Limited lifetime warranty
- Designed For
- Microsoft Surface Laptop, Laptop Go, Laptop SE, Laptop Studio, Pro, Pro X
- Product Type
- Product Material
- 600D polyester
- 41 cm
- 9 cm
- 31 cm
- 780 g
- 15"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3.5 cm
- Additional Compartments
- Mobile phone, pens, power bank, internal pockets, document compartment, 10.5" tablet
- Carrying Strap
- Black
- Limited warranty: - 30 years
- Designed For
