SmartSkin from DICOTA is the ideal solution for all users wishing to transport their Notebook in a simple yet flexible manner. SmartSkin is made from robust and particularly flexible neoprene and fits snugly around your Notebook like a second skin, thereby ensuring that your computer has optimum protection from scratches. A further advantage: the zip is equipped with extra protection on the inside to prevent scratches to your Notebook whilst packing or unpacking it.
SmartSkin is equipped with a practical handle so that you can conveniently carry it around. Two small pockets on the front of the case also ensure that small accessories are always neatly stowed away and are within easy reach.
Durable construction
The laptop sleeve is made from 100% recycled fabric, demonstrating environmental responsibility while maintaining strength. -
Secure closure system
The double zipper closure allows for easy access while ensuring that your laptop remains safely inside the sleeve during transport. -
Water-repellent fabric
With its water-repellent qualities, this sleeve helps protect your devices from unexpected spills or rain, ensuring they stay dry. -
Ample storage space
Featuring a front zippered pocket, this sleeve provides additional space for storing chargers, pens, and other accessories, making it a suitable companion for your laptop. -
Comfortable portability
Equipped with padded carry handles, the sleeve ensures a comfortable grip while carrying your laptop, making it easy to transport.
- DICOTA Smart - notebook sleeve
- Product Type
- Notebook sleeve
- Black
- Product Material
- Neoprene, 100% recycled fabric
- 41 cm x 29 cm x 3 cm
- 350 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 15" - 15.6" / 38.1 cm - 39.6 cm
- Water repellent
- Carrying Strap
- Padded carry handles
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- 41 cm
- 29 cm
- 3 cm
- 350 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3 cm
- Additional Compartments
- Front zippered pocket
- Carrying Strap
- Closure Type
- Double zipper
- Lining Material
- Nylex
- Black
- Water repellent
- Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Dicota Smart Skin 15-16"
