Dicota Smart Skin 15-16"
Quicklinx: HV50WS00 Mfr#: D31182-RPET
£23.39 ex VAT
£28.06 inc VAT
SmartSkin from DICOTA is the ideal solution for all users wishing to transport their Notebook in a simple yet flexible manner. SmartSkin is made from robust and particularly flexible neoprene and fits snugly around your Notebook like a second skin, thereby ensuring that your computer has optimum protection from scratches. A further advantage: the zip is equipped with extra protection on the inside to prevent scratches to your Notebook whilst packing or unpacking it.
SmartSkin is equipped with a practical handle so that you can conveniently carry it around. Two small pockets on the front of the case also ensure that small accessories are always neatly stowed away and are within easy reach.
  • Durable construction
    The laptop sleeve is made from 100% recycled fabric, demonstrating environmental responsibility while maintaining strength.
  • Secure closure system
    The double zipper closure allows for easy access while ensuring that your laptop remains safely inside the sleeve during transport.
  • Water-repellent fabric
    With its water-repellent qualities, this sleeve helps protect your devices from unexpected spills or rain, ensuring they stay dry.
  • Ample storage space
    Featuring a front zippered pocket, this sleeve provides additional space for storing chargers, pens, and other accessories, making it a suitable companion for your laptop.
  • Comfortable portability
    Equipped with padded carry handles, the sleeve ensures a comfortable grip while carrying your laptop, making it easy to transport.
DICOTA Smart - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
41 cm x 29 cm x 3 cm
350 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 15.6" / 38.1 cm - 39.6 cm
Water repellent
Carrying Strap
Padded carry handles
Notebook sleeve
Product Material
41 cm
29 cm
3 cm
350 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Additional Compartments
Front zippered pocket
Carrying Strap
Closure Type
Double zipper
Lining Material
Nylex
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
