On the front there is a zip pocket with room for your accessories. Smart Skin has padded handles for your comfort when carrying, but the handles are slim enough to not add any bulk on the occasions you want to put the sleeve inside another bag.
- DICOTA SmartSkin Laptop Sleeve 15.6" - notebook sleeve
- Product Type
- Notebook sleeve
- Black
- Product Material
- Neoprene
- 41 cm x 29 cm x 3 cm
- 300 g
- Notebook Compatibility
- 15.6"
- Carrying Strap
- Hand grip
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 41 cm
- 29 cm
- 3 cm
- 300 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 4 cm
- Additional Compartments
- Documents, mobile accessories
- Carrying Strap
- Hand grip
- Closure Type
- Zipper
- Lining Material
- Nylex
- Black
- Limited warranty: - lifetime
