Dicota Smart Skin 14-14.1"
Quicklinx: HV4ZWS00 Mfr#: D31181-RPET
£22.05 ex VAT
£26.46 inc VAT
SmartSkin from DICOTA is the ideal solution for all users wishing to transport their Notebook in a simple yet flexible manner. SmartSkin is made from robust and particularly flexible neoprene and fits snugly around your Notebook like a second skin, thereby ensuring that your computer has optimum protection from scratches. A further advantage: the zip is equipped with extra protection on the inside to prevent scratches to your Notebook whilst packing or unpacking it.
SmartSkin is equipped with a practical handle so that you can conveniently carry it around. Two small pockets on the front of the case also ensure that small accessories are always neatly stowed away and are within easy reach.
  • Eco-friendly construction
    This notebook sleeve is crafted from 100% recycled fabric, promoting sustainability and reducing environmental impact.
  • Water-repellent material
    The water-repellent feature helps keep your laptop dry, protecting it from unexpected spills or rain.
  • Comfortable carrying options
    Equipped with padded carry handles, this sleeve allows for easy and comfortable transportation of your laptop.
  • Smart storage solution
    The front zippered pocket provides extra space for accessories, ensuring that everything you need is within reach.
  • Compatible with various laptop sizes
    Designed for laptops with sizes ranging from 14" to 14.1", this sleeve offers a snug fit and protection.
DICOTA Smart - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
37.5 cm x 27.5 cm x 2.5 cm
310 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
14" - 14.1" / 35.6 cm - 35.8 cm
Water repellent
Carrying Strap
Padded carry handles
Notebook sleeve
Product Material
37.5 cm
27.5 cm
2.5 cm
310 g
14.1"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 3 cm
Additional Compartments
Front zippered pocket
Carrying Strap
Closure Type
Double zipper
Lining Material
Nylex
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
