Dicota Smart Skin 12-12.5"
Quicklinx: HV4XWS00 Mfr#: D31179-RPET
10 In Stock
£19.74 ex VAT
£23.68 inc VAT
SmartSkin from DICOTA is the ideal solution for all users wishing to transport their Notebook in a simple yet flexible manner. SmartSkin is made from robust and particularly flexible neoprene and fits snugly around your Notebook like a second skin, thereby ensuring that your computer has optimum protection from scratches. A further advantage: the zip is equipped with extra protection on the inside to prevent scratches to your Notebook whilst packing or unpacking it.
SmartSkin is equipped with a practical handle so that you can conveniently carry it around. Two small pockets on the front of the case also ensure that small accessories are always neatly stowed away and are within easy reach.
  • Environmentally friendly materials
    This notebook sleeve utilizes 100% recycled fabric alongside neoprene, combining sustainability with durability.
  • Water-repellent construction
    The water-repellent feature ensures that your devices are safeguarded from unexpected spills or rain.
  • Convenient storage options
    A front zippered pocket allows for the organization of essential accessories while on the go.
  • Secure and easy access
    The double zipper closure provides quick access to your laptop, making it convenient for busy professionals.
  • Comfortable carrying experience
    Padded carry handles enhance comfort during transport, ensuring ease of mobility.
DICOTA Smart - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
33.5 cm x 24 cm x 2.5 cm
270 g
Notebook Compatibility
12.5"
Notebook Supported Sizes
12" - 12.5" / 30.5 cm - 31.8 cm
Water repellent
Carrying Strap
Notebook sleeve
Product Material
33.5 cm
24 cm
2.5 cm
270 g
12.5"
Notebook Compatibility Dimensions
31.5 cm x 21.5 cm x 3 cm
Additional Compartments
Front zippered pocket
Carrying Strap
Closure Type
Double zipper
Lining Material
Nylex
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
