Simplicity. Functionality. Inspired, contemporary design. These are the guiding principles that define the EDGE product family. Exceptional materials and highlights accentuate your own individual style. The Slim Case Plus EDGE is designed to fit Ultrabooks while offering maximum protection. The EVA foam within the main compartment perfectly adapts to the contours of your device.
- DICOTA Slim Case Plus EDGE - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 600D polyester
- 36 cm x 6 cm x 25 cm
- 500 g
- Notebook Compatibility
- 13.3"
- Notebook Supported Sizes
- 12" - 13.3" / 30.5 cm - 33.8 cm
- Zippered, padded, padded handles, removable shoulder strap, up 10.5" tablet support
- Carrying Strap
- Shoulder carrying strap, trolley strap, padded hand strap
- Limited lifetime warranty
- Product Type
- Product Material
- 600D polyester
- 36 cm
- 6 cm
- 25 cm
- 500 g
- 13.3"
- Notebook Compatibility Dimensions
- 33 cm x 23 cm x 3 cm
- Additional Compartments
- Mobile phone, cable, documents, mobile accessories, tablet
- Carrying Strap
- Closure Type
- Zipper
- Black
- Limited warranty: - lifetime
