Dicota Slim Case Plus EDGE Notebook Carrying Case 12-13.3" - Black
Quicklinx: DR17WS00 Mfr#: D31516
Simplicity. Functionality. Inspired, contemporary design. These are the guiding principles that define the EDGE product family. Exceptional materials and highlights accentuate your own individual style. The Slim Case Plus EDGE is designed to fit Ultrabooks while offering maximum protection. The EVA foam within the main compartment perfectly adapts to the contours of your device.
DICOTA Slim Case Plus EDGE - notebook carrying case
Notebook carrying case
Product Material
600D polyester
36 cm x 6 cm x 25 cm
500 g
Notebook Compatibility
13.3"
Notebook Supported Sizes
12" - 13.3" / 30.5 cm - 33.8 cm
Zippered, padded, padded handles, removable shoulder strap, up 10.5" tablet support
Carrying Strap
Shoulder carrying strap, trolley strap, padded hand strap
Product Material
600D polyester
36 cm
6 cm
25 cm
500 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 3 cm
Additional Compartments
Mobile phone, cable, documents, mobile accessories, tablet
Carrying Strap
Closure Type
Zipper
Limited warranty: - lifetime
