Slim Case BASE is a lightweight carrying solution for your personal device. Your notebook is well protected thanks to the cushioned notebook compartment. With the help of a removable strap, the notebook is kept in place inside the bag. You can either carry the bag with the comfortable neoprene handles or use the detachable shoulder strap.
Documents can conveniently be stored in the designated slip pocket at the backside of the bag. The functional front pocket offers enough space to store accessories and other personal belongings you want to have close at hand. This makes Slim Case BASE the perfect bag for those on the go.
 - DICOTA Slim Case BASE - notebook carrying case
- Product Type
 - Notebook carrying case
 - Grey
- Product Material
 - Polyester, neoprene
 - 40 cm x 4 cm x 29 cm
 - 380 g
- Notebook Compatibility
 - 15.6"
- Notebook Supported Sizes
 - 15" - 15.6" / 38.1 cm - 39.6 cm
 - Zippered, back slip pocket, front pocket
- Carrying Strap
 - Removable shoulder strap, padded top handles
 - 2-year warranty
- Product Type
- Product Material
 - 40 cm
 - 4 cm
 - 29 cm
 - 380 g
 - 15.6"
- Notebook Compatibility Dimensions
 - 38.5 cm x 26.5 cm x 3 cm
- Additional Compartments
 - Mobile phone, documents, pens, personal accessories, mobile accessories
- Carrying Strap
 - Grey
 - Limited warranty: - 2 years
