Dicota Sleeve ONE 13-13.3"
Quicklinx: HQFMWS00 Mfr#: D32079-RPET
More than 50 In Stock
£9.04 ex VAT
£10.84 inc VAT
The DICOTA ONE notebook sleeve provides durable protection for laptops up to 13.3 inches in size. Crafted from recycled jersey fabric, this sleeve prioritizes sustainability while effectively safeguarding your device from scratches and everyday wear. The zipper closure ensures easy access while keeping your notebook securely inside.
Ideal for individuals who prioritize both style and functionality, this notebook sleeve combines a sleek design with practical features. The lightweight construction makes it easy to carry, while its compact dimensions allow for convenient storage in backpacks or briefcases. The DICOTA ONE sleeve is a choice for anyone looking to protect their device without compromising on aesthetics.
  • Durable material
    Constructed from recycled jersey fabric, this notebook sleeve is built to withstand daily use while minimizing environmental impact.
  • Secure closure
    Featuring a zipper closure, this sleeve keeps your notebook safely inside, allowing for peace of mind while on the go.
  • Scratch-resistant design
    The scratch-resistant surface of the sleeve prevents unsightly marks, ensuring that your device maintains a sleek appearance.
  • Compatible dimensions
    Designed to fit notebooks ranging from 13 inches to 13.3 inches, this sleeve provides a snug and secure fit for a variety of devices.
  • Portable and lightweight
    With its compact dimensions and lightweight structure, the DICOTA ONE sleeve makes it easy to take your laptop anywhere.
DICOTA ONE - notebook sleeve
Notebook sleeve
Product Material
Recycled jersey fabric
35 cm x 25 cm x 2.5 cm
119 g
Notebook Compatibility
13.3"
Notebook Supported Sizes
13" - 13.3" / 33 cm - 33.8 cm
Scratch-resistant
5-year warranty
Notebook sleeve
Product Material
35 cm
25 cm
2.5 cm
119 g
13.3"
Notebook Compatibility Dimensions
33 cm x 23 cm x 3 cm
Closure Type
Zipper
Scratch-resistant
Limited warranty: - 5 years
Brand: Dicota
