Elegant and minimalistic: the high-quality design of the skin perfectly matches the shape of your MacBook. The skin features a soft faux fur lining that protects it from scratches and dust.
A mobile lifestyle demands practical solutions. The compact sleeve is made of elastic neoprene and can be stowed anywhere, whether in a backpack, bag or as an eye-catcher in your hand. The leather accents add great fashionable touches. The Skin URBAN is available in different colours and sizes.
Made of durable elastic neoprene
Fits your MacBook Air 15" M2 like a second skin
Soft faux fur lining protects against dust and scratches
Great design.
Enhanced protection
The DICOTA urban sleeve offers superior protection against dust and scratches, thanks to its durable neoprene material and soft faux fur lining. Ideal for safeguarding your notebook during travel or daily commutes. -
Sleek design
Featuring a minimalist design with a convenient zipper closure, this notebook sleeve combines functionality with style. Its slim profile does not add bulk, making it easy to carry or fit into another bag.
- DICOTA urban - notebook sleeve
- Product Type
- Notebook sleeve
- Grey
- Product Material
- Neoprene
- 37 cm x 27 cm x 2 cm
- 210 g
- Scratch protection, dust protection
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 37 cm
- 27 cm
- 2 cm
- 210 g
- Inner Dimensions
- 35 cm x 27 cm x 2 cm
- Closure Type
- Zipper
- Lining Material
- Faux fur
- Grey
- Limited warranty: - lifetime
