Elegant and minimalistic: the high-quality design of the URBAN skin perfectly matches the shape of your device. The skin features a soft faux fur lining that protects it from scratches and dust. The compact sleeve is made of an elastic neoprene material. It is light, durable and powerful thanks to its sturdy design.
- DICOTA Skin URBAN - notebook sleeve
- Product Type
- Notebook sleeve
- Anthracite
- Product Material
- Neoprene
- 36 cm x 2 cm x 26.5 cm
- 230 g
- Notebook Compatibility
- 15"
- Limited lifetime warranty
- Designed For
- Apple MacBook Pro (15.4 in)
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 36 cm
- 2 cm
- 26.5 cm
- 230 g
- 15"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 2.5 cm
- Closure Type
- Zipper
- Lining Material
- Faux fur
- Anthracite
- Limited warranty: - lifetime
- Designed For
