Flexible, resistant and strong: the sleeves from the FLOW family have been designed to fit your notebook perfectly - like a second skin. Your device will be kept safe during your commute to the office or university. The outside of the sleeve is made from durable, elastic neoprene.
- DICOTA Skin FLOW - notebook sleeve
- Product Type
- Notebook sleeve
- Grey, green
- Product Material
- Neoprene
- 41 cm x 2 cm x 29 cm
- 280 g
- Notebook Compatibility
- 15.6"
- Notebook Supported Sizes
- 15" - 15.6" / 38.1 cm - 39.6 cm
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 41 cm
- 2 cm
- 29 cm
- 280 g
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 3 cm
- Closure Type
- Zipper
- Lining Material
- Soft nylex
- Grey, green
- Limited warranty: - lifetime
