Dicota Skin FLOW 15-15.6 - Grey/Green
Quicklinx: FS3FWS00 Mfr#: D31747
Flexible, resistant and strong: the sleeves from the FLOW family have been designed to fit your notebook perfectly - like a second skin. Your device will be kept safe during your commute to the office or university. The outside of the sleeve is made from durable, elastic neoprene.
DICOTA Skin FLOW - notebook sleeve
Notebook sleeve
Grey, green
Product Material
Neoprene
41 cm x 2 cm x 29 cm
280 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 15.6" / 38.1 cm - 39.6 cm
Notebook sleeve
Product Material
Neoprene
41 cm
2 cm
29 cm
280 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Closure Type
Zipper
Lining Material
Soft nylex
Grey, green
Limited warranty: - lifetime
