Dicota Security Cable T-Lock, combination, 3x7mm slot
Quicklinx: GFPSWS00 Mfr#: D30885
£20.91 ex VAT
£25.09 inc VAT
This DICOTA lock works without a key and fits almost all standard lock slots. Notebooks, projectors, printers and monitors can be effectively secured. With a length of 200 cm. The 4-digit combination allows you to set your individual number code and up to 10,000 possible number combinations ensure the necessary security.
  • Enhanced security
    This security cable lock from DICOTA is designed to provide a robust layer of protection for PCs. Made from high-grade steel, it's built to withstand attempts at tampering or cutting, ensuring your device remains secure in public spaces or offices.
  • User-friendly design
    Featuring a combination lock, this security solution offers a convenient, keyless way to secure your devices. The ease of setting and changing combinations means you can maintain high security without the hassle of managing keys.
DICOTA - security cable lock
Security cable lock
Product Material
Steel
Length
2 m
200 g
Combination lock
Security cable lock
Product Material
Steel
Length
2 m
200 g
Combination lock
Brand: Dicota
