Notebooks are becoming thinner and yet increasingly versatile. The lightweight and particularly sleek ultra slim locks reliably protect your device without adding unnecessary bulk. Also projectors, monitors and printers can be effectively secured with the DICOTA locking systems. Currently, device manufacturers use three different formats for the lock slots. The Security Cable Nano Lock Ultra Slim is suitable for all models with a 2.5 x 6 mm slot and compatible with the Kensington Nano Security Slot.
A foam buffer prevents scratches on the device. Enjoy high flexibility in workplace design thanks to the swiveling and rotatable closing head. The push-to-lock function allows you to secure the lock without a key using one hand. Quick, simple and reliable. The sheathed multi-strand steel cable is 2 m long and has a diameter of 4.4 mm. The functional Velcro strap allows the cable to be rolled up for compact storage and transportation. Two keys are included as part of the delivery. This lock is used in a superordinate lock system, which allows access for individual users as well as the system administrator via a master key. Each system is individually designed and manufactured specifically for you.
 - DICOTA - security cable lock - ultra slim
- Product Type
 - Security cable lock - ultra slim
- Package Content
 - 2 x keys
 - Silver
- Product Material
 - Zinc alloy
- Length
 - 2 m
 - 120 g
 - Master keyed, 4.4 mm diameter
 - 2-year warranty
- Product Type
- Product Material
 - Zinc alloy
- Package Content
 - 2 x keys
- Length
 - 2 m
 - 120 g
 - Silver
Security Cable Lock
- Intended For
 - Notebook
- Lock Type
 - Nano
- Lock Method
 - Key
 - Limited warranty: - 2 years
