A notebook can be stolen in an instant. Expensive hardware and important data are lost. This can also involve a lot of work and great expense. Police, insurance, data recovery etc. Targeted prevention is the answer. With a quality lock from DICOTA. Easy, convenient and effective. Ideal for use in the office, in cars or in hotels.
This DICOTA lock fits all standard Nano Lock (Kensington Nano Security Slotâ„¢*) slots: notebooks, projectors, printers and monitors can be effectively secured. With a length of 200 cm and a diameter of 4.4 mm, the steel cable is designed to be extra long and extra strong. Notebooks, projectors, printers and monitors can be effectively secured. The 4-digit combination allows you to set your individual number code out of 10.000 possible number combinations ensure the necessary security. This lock is a standalone version and cannot be integrated into a superordinate lock system.
Enhanced security
Equipped with a 4-digit code and designed for a 2.5 x 6 mm slot, this security cable lock offers robust theft protection for your notebook. Its combination lock method ensures your device remains secure, providing peace of mind in public spaces. -
Versatile design
Featuring a rotatable construction, this security cable lock offers flexibility and ease of use. Made from durable alloy and zinc, it's built to withstand attempts at tampering, ensuring your device stays where you left it. -
Dedicated compatibility
Specifically intended for notebooks, this security cable lock fits perfectly with devices equipped with a nano lock type. The inclusion of 3 spacers ensures a snug fit for a wide range of notebook models, offering tailored security solutions.
 - DICOTA - security cable lock
- Product Type
 - Security cable lock
- Package Content
 - 3 spacers
 - Anthracite
- Product Material
 - Zinc, alloy
- Length
 - 2 m
 - 140 g
 - 4 digit code, rotatable, for 2.5 x 6 mm slot, theft protection
 - 2-year warranty
- Product Type
- Product Material
 - Zinc, alloy
- Package Content
 - 3 spacers
- Length
 - 2 m
- Diameter
 - 4.4 mm
 - 140 g
 - Anthracite
Security Cable Lock
- Intended For
 - Notebook
- Lock Type
 - Nano
- Lock Method
 - Combination
 - Limited warranty: - 2 years
